It is currently Fri Sep 19, 2025 1:22 am
PostPosted: Wed Sep 02, 2020 5:14 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
I've got a maple neck blank and fretboard. I'd like to create some separation between the two. I was thinking of using a darker wood veneer sandwiched between the two. Should I anticipate any problems? I'm wondering specifically about when it comes time to sand, will the dark wood dust from the veneer stain the lighter maple?
PostPosted: Wed Sep 02, 2020 6:26 pm
My experience has been that once you get to the higher grits the sanding scratches no longer seem to hold the dark sawdust..
These users thanked the author Clay S. for the post (total 2): Pmaj7 (Fri Sep 04, 2020 12:32 am) • Conor_Searl (Thu Sep 03, 2020 11:13 am)
PostPosted: Wed Sep 02, 2020 6:29 pm
Online
First name: Tim
Last Name: Allen
City: San Francisco
My experience is the same as Clay's regarding this. Maple is hard and has very small pores. I've never had a problem. The picture shows EIR sides w/blue side purfling next to maple binding. No sanding dust got into the binding.
Depending on your veneer, you might need to be careful about color bleeding from it to the maple when you apply finish. There are ways to manage this. If your veneer is walnut, it probably won't bleed much; if it's cocobolo, look out. They are all different. Just test first on a sample before you finish.
Tim Allen
"Never hurry, never rest."
These users thanked the author TimAllen for the post: Conor_Searl (Thu Sep 03, 2020 11:13 am)
PostPosted: Thu Sep 03, 2020 10:52 am
First name: D
Last Name: S
I glue the neck, veneer, and fretboard all at the same time.
Some water-based glues will expand and then shrink the veneer which can cause warping.
I cut the veneer into three long strips to add “expansion” joints.
I have no idea if this is necessary, but I figure it can’t hurt.
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: Conor_Searl (Thu Sep 03, 2020 11:13 am)
PostPosted: Thu Sep 03, 2020 12:06 pm
Once you get to about 220 grit the sanding scratches are smaller than the pore size, so it's not a problem.
I have found that the key to using water based glues for large joints is to leave things in the clamps until the water dries out. Sure, the glue may be hard in 45 minutes, but it can take a lot longer for the water to get out. Once it does you're fine. I try to wait at least over night, and 24 hours is even better.
These users thanked the author Alan Carruth for the post (total 2): Conor_Searl (Fri Sep 04, 2020 11:22 am) • Bryan Bear (Thu Sep 03, 2020 4:46 pm)
Users browsing this forum: TimAllen and 21 guests
